[ROM]【5.1】Google Play Edition【JFLTE-GPE】- 2015-09-19
#121
Re: [ROM]【5.0.1】Google Play Edition【JFLTE-GPE】- 14-06-2015
Messagepar angelcalibur » 19 Juin 2015, 11:12
Mise a jour de la rom:
http://ultimarom.com/google-play-editio ... 6-13-2015/
06/14/2015
Fixed Google Keyboard
Fixed OTA Updates not downloading properly (v2.4.5)
06/13/2015
Fixed Google Now FCing when used
Made alucard_24's kernel the default
Worked with him to rebase his GE5.0 kernel to be fully up to date
Christopher GCC 4.9.3 compiled
Optimised for speed (-O3)
Removed all installer options now. Installer simply installs. Hulk or Googy kernel can be found in their threads
Stock GE kernel in addons
DPI changing in Interface app
Fixed a small bug in OTA Updates, version is now v2.4.4
Better supersu installation method in installer. Won't affect users, but makes it easier for me.
New Android M default wallpaper
Updated Google Camera, Keyboard and Chrome
Galaxy S8+ (SM-G955F)
rom: stock 7.0
bande de base : G955FXXU1AQDD
angelcalibur
Message(s) : 1269
#122
Re: [ROM]【5.1】Google Play Edition【JFLTE-GPE】- 2015-09-10
Messagepar angelcalibur » 11 Sep 2015, 09:44
2015-09-10
Nouvelle mise a jour, cette fois avec Android 5.1! ;)
le lien : https://www.androidfilehost.com/?fid=24052804347812662
Apparemment il y a "peut être" un soucis avec l’appareil photo mais c'est a tester! mais sinon la rom marche vraiment bien d'après certains de mes contacts (Team JDC)
Les info du dev (en anglais désolé mais google traduction est votre amis :lol: ) :
right out the gate you will notice this thing is fast! I haven't encountered one issue yet except for the Camera, but I believe a firmware upgrade will do the trick but as of right now on 4.x bootloaders/firmware it will not connect to camera
here is what I want you guys to try while I sleep
Odin to stock latest Samsung firmware to upgrade bootloaders/modem/etc
Boot 5.x touchwiz
Open Samsung Camera to make sure its working and on the latest firmware
reboot to download mode
Install custom recovery
full wipe
flash 5.1 initial build
test camera
things I've done so far:
Debloated all the google market apps
Rooted and integrated root into Settings
Long press recents
Tethering unlock for some carriers
rom: stock 7.0
angelcalibur
Message(s) : 1269
#123
Re: [ROM]【5.1】Google Play Edition【JFLTE-GPE】- 2015-09-14
Messagepar angelcalibur » 14 Sep 2015, 12:03
Nouvelle version :
https://romhut.com/versions/jflte-gpe-20150914-zip
Pas de changelog puisque c'est une version initiale en 5.1!
rom: stock 7.0
angelcalibur
Message(s) : 1269
#124
Re: [ROM]【5.1】Google Play Edition【JFLTE-GPE】- 2015-09-16
Messagepar angelcalibur » 16 Sep 2015, 09:28
Nouvelle version du 16/09:
https://romhut.com/versions/jflte-gpe-20150916-zip
Changelog :
FULL WIPE! DO NOT DIRTY FLASH FROM 5.0.1
-Now ships with GPE-5.1 kernel patched to linux 3.4.108 based off of Googy 1.3 (includes 5.1 source) by @Tkkg1994
-Random reboots are fixed for INTL I9505 users
-Loki patch will work on the kernel
-External storage will now mount
-Latest APN list from CyanogenMOD
-Teleservice network modes unlocked, enabled world phone
-added Framework values so select MVNO networks will not be "roaming"
-Fixed alignment of keyguard carrier text
-HSPA icon enabled
-App ops added to Settings>Security
-Nexus UI sounds
known issues: (CDMA users)
Sprint and Verizon might need to set defaultnetwork in build.prop to "8"
Verizon and Sprint SMS may not work
rom: stock 7.0
angelcalibur
Message(s) : 1269
#125
Re: [ROM]【5.1】Google Play Edition【JFLTE-GPE】- 2015-09-19
Messagepar angelcalibur » 21 Sep 2015, 10:36
Nouvelle mise a jour:
https://romhut.com/versions/jflte-gpe-20150919-zip
-Back to Stock kernel, I9505 users will need to flash my custom kernel if they are experiencing random reboots (In the OP)
-Extracted System.img
-Added missing Camera permission to updater-script (Thanks AntaresOne)
-Updated the AROMA installer splash image
-Reverted HSPA status bar icon back to 3g Icon (Stock GPE)
-Menu button will no longer unlock the lock screen
-Updated all Google apps including playstore and google play services
-Fixed apns-conf.xml for most carriers
-Removed unnecessary Samsung leftovers
rom: stock 7.0
angelcalibur
Message(s) : 1269
#126
Messagepar ViviVang » 10 Oct 2015, 15:18
Rom installé mercredi. Fluide, aucun problème de wifi ou de caméra. Juste des redémarrages intempestifs. De 4 à une dizaine par jour (et des fois rien).
Installer directement depuis la 20150919. Avec tous les wipes, factory reset.
Retour sur la rom Samsung, plus de redémarrages, de retour sur cette rom, ça recommence. Donc instable. Mais je vais y rester dessus et attendre une MAJ.
Edit : Pour info, pour ceux qui ont les problèmes de redémarrages aléatoires comme moi, il y a un patch à flasher.
https://www.androidfilehost.com/?fid=24052804347816655
Envoyé de mon GT-I9505G en utilisant Tapatalk
Raison: fusion double post
Téléphone : Galaxy S4 GT-I9505
Firmware : Firmware officiel I9505XXUFNC4
Version Android : 4.4.2
Opérateur : Free forfait 15€99
Téléphone : Xiaomi Mi3 16Go
Firmware : MIUI V5
Opérateur : Free forfait 2€
ViviVang
Message(s) : 9
#127
Messagepar kyfran » 17 Oct 2015, 17:44
salut a tous. je viens d'installer cette rom et je n'ai pas eu le menu AROMA est-ce normal ?
merci d'avance
Modèle : Samsung Galaxy S (GT-I9505)
[Android 5.0.1] I9505XXUHOF2
i9505XXUHOF2
recovery philz touch 6.59.0
kyfran
Message(s) : 271
#128
Messagepar ViviVang » 18 Oct 2015, 12:43
Il me semble que la toute dernière ROM ne l'a pas. Celle d'avant oui.
Mais cela ne cause aucun problème durant l'installation. Tu peux directement installer via la dernière ROM.
Et tu fais tous les wipes si tu pars d'une autre ROM ou si tu veux partir à neuf.
Firmware : MIUI V5
ViviVang
Message(s) : 9
#129
Messagepar kyfran » 18 Oct 2015, 13:41
salut. merci pour ta réponse. mais du coup je n'avais pas d'application sms, ni internet.
je peux installer AROMA depuis la derniere ROm ?
merci
i9505XXUHOF2
kyfran
Message(s) : 271
#130
Messagepar Genzo33 » 18 Oct 2015, 15:20
ROM installée aucun soucis à signaler juste de nouvelles habitudes à prendre.
Sinon wifi OK, bluetooth OK, GPS OK, appel et réseau OK
Pour l'instant j'ai qu'un soucis c'est la mise à jour OTA qui est poussée que j'arrive pas à installer
Samsung Note 4: 32 Go + 32 Go
Version: N910FXXS1DQE1_N910FOXX1DPI1_XEF (Mai 2017)
Genzo33
Message(s) : 10
