[ROM AOSP][KitKat 4.4.2] Mackay ROM CM11.0 -09/jan/2014
Messagepar papa50 » 11 Déc 2013, 17:19
ALLER ENCORE PLUS LOIN AVEC :
[KK 4.4][ROM]Mackay ROM 4.1.5 CM11.0
Avertissements :
je ne suis pas responsable , ni CyanogenMod, ni le forum galaxys-team, ni kasper_h ne seront tenus responsable en cas de non fonctionnement de votre bébé (galaxy s) !
Veuillez toujours sauvegarder vos données, applis,sms,mms,images !
faire une sauvegarde complète de la Rom ( Recovery) , ou par titanium backup
Le lien xda :
http://forum.xda-developers.com/showthr ... ?t=2529461
Changelog of 4.1.5 - 21-Dec-2013
-CM11.0 codebase of 21-Dec -> updated to 4.4.2
-Added more CM security settings
-Many small fixes to code
Changelog du 4.1.3 - 9-Dec-2013
-CM11.0 codebase of 10-Dec
-Fix to DeskClock
Full changelog of 4.1.3 compared to stock CM11.0:
CM11.0 sources of 10-Dec-2013
All features compared to stock kernel:
Separate kernel thread: http://forum.xda-developers.com/showthr ... ?t=2532813
-Mackay kernel 0.603:
-Christopher86's cortex-A8 optimized Linaro toolchain (November version)
-O3 optimization
-updated to linux kernel version 3.0.101
-SLQB memory allocator (default, should be slightly faster)
-XZ compression of kernel & initramfs
-396MB RAM
-SIOplus scheduler
-Added Lagfree governor
-ROW scheduler (tweaked, default scheduler)
-FIOPS scheduler (tweaked)
-many improvements to IO schedulers in general
-Deadline tuning (thanks to DerTeufel)
-Ondemand tuned (updated based on code of stratosk)
-SmartassV2 governor
-OndemandX governor
-Interactive governor (updated to android 3.4 code + fixes)
-Wheatley & Lulzactive governors
-Conservative tuned
-Call volume hack (use “Settings>Mackay Settings”* to set volumes)
-Reduced battery polling interval
-Fast charge (activate through “Settings>Advanced Settings”* or the QuickCharge toggle in MackayROM)
-WiFi PM_FAST mode selection (activate using “Settings>Mackay Settings”*)
-Battery life extender (set through “Settings>Mackay Settings”*)
-CustomVoltage (set using NSTools)
-USB OTG support (needs external power supply)
-1100-1400MHz OC steps
-Custom kernel splash (Thanks to Malcho)
-Updated charging logo to match open charger
-Disabled swap & zram
-Improve memcopy/memmove
-Improve the performance of memcpy and memmove
-Kill task closest in size to memory needed to free
-LOAD_FREQ (4*HZ+61) avoids loadavg Moire
-Entropy tweaks: http://lwn.net/Articles/489734/
-backport CPUIDLE from 3.5
-arm/crypto: Add optimized AES and SHA1 routines
-Unaligned CPU access
-Improvements to RWSEM code
-Improvements to binder code
-Improvements to tmpfs
-Added frandom (much faster random number generator)
-Updated to lowmemorykiller with PID whitelist (thanks to stratosk)
-Many parts of the code build as module to reduce effective kernel size
-Updated wifi driver to 5.90.195.114
-Updated GPU driver to DDK 1.8@2198402
-Proportional Rate Reduction for TCP
-Introduce timer slack controller
-Zram patched
-Low RAM switch option (default off)
ROM comes with stock colour. Version with voodoo colour can be downloaded from:
Liens ROM 10/12/2013
Downloads:
XDAfileserver:
http://www.xdafileserver.nl/index.php?d ... ROM%2FKK44
Rootaxbox :
http://rootaxbox.no-ip.org/kasper_h/roms/KK44/
Lien GAPPS :
http://d-h.st/users/dhacker29?fld_id=27426
autre lien : du 08/12/2013 (merci lolo) ;)
http://wiki.cyanogenmod.org/w/Gapps
du 16/12/2013 :
http://www.androidfilehost.com/?a=show& ... flid=10306
installation:
1)
-faire vos sauvegardes
2)
-Faîtes un wipe cache partition,
-un wipe dalvik
-puis un factory reset dans le recovery
3)
-Flashez un premiere fois la rom
4)
-Installer les gapps
5)
-Flasher une deuxieme fois la rom
6)
-un reboot
7)
-Etre patient c’est assez long je trouve hiiii… :roll:
8)
-bonne dégustation de votre kitkat mackay
une petite suggestion : de lolo91 merci ;)
réglages de base pour l'utilisateur :
- comme pour la 4.3, il faut aller cliquer 7 fois dans "A propos du téléphone / numéro de build", pour activer le mode développeur (et donc avoir accès à ce menu et au redémarrage facile en mode recovery).
- kasper_h conseille d'activer le mode low ram ; ("Mackay settings/activate low ram settings" et ne pas oublier de cocher en bas : "apply settings" et rebooter). C'est une feature de KK qui permet à l'OS d'être plus fluide avec un smartphone 512M comme le notre.
- une petite subtilité de KK : pour créer un écran d'accueil supplémentaire il faut déplacer un icone de raccourci d'app. à droite du dernier écran.
Remerciements :
- kasper_h et :
- teamhacksung/pawitp for making CyanogenMod work on our ancient phone
-stratosk/DerTeufel/Mialwe for the inspiration I got from their kernels
-rootax & xdafileserver for providing a high-speed server for high quality downloads
-Malcho for his kernel splash & bootanimation
-oli,chris,lolo pour vos conseils ;)
Téléphone : GT I9000[/color]
Version d'Android : KITKAT 4.4
Modem ril : I9000XXJVU GSTEAM
ROM jb11: RESURRECTION kitkat 4.4.2
KERNEL :Mackay
Gapps :2013-12-08
papa50
Message(s) : 220
Re: [KK 4.4][ROM]Mackay ROM 4.1.3 CM11.0 (10-Dec-2013)
Messagepar papa50 » 11 Déc 2013, 17:58
KERNEL :Mackay
Gapps :2013-12-08
papa50
Message(s) : 220
Messagepar papa50 » 11 Déc 2013, 17:59
reservé 2 ;)
KERNEL :Mackay
Gapps :2013-12-08
papa50
Message(s) : 220
reservé 3 ;)
KERNEL :Mackay
Gapps :2013-12-08
papa50
Message(s) : 220
Messagepar oli87 » 11 Déc 2013, 20:23
Bonne initiative Papa ;)
SAMSUNG GALAXY S6 (SM-G920F) Noir Saphir / 32 Go
Firmware d'origine : G920FXXU1AOD9
Opérateur : BOUYGUES / Forfait 4G Sensation 24/24 3Go
Config actuelle :
Passé en 5.1.1 G920FXXU2COH2
oli87
Message(s) : 1965
Messagepar chris59264 » 12 Déc 2013, 16:15
Bonjour et merci, donc l'install c'est flash rom +flash kernel ?? .Sur xda c'est juste flash rom. Ca m'semble bizarre ,tu a une explication ?,merci.
Bonne initiative pour ce topic,nikel.
galaxy s 1 . Omni rom mackay 4.4.2.modem bvjv2 ,operateur free
chris59264
Message(s) : 2994
Messagepar papa50 » 12 Déc 2013, 17:01
Merci a vous ;)
Oui Chris tu as raison
Je les ai rajouté au cas ou ;)
KERNEL :Mackay
Gapps :2013-12-08
papa50
Message(s) : 220
Messagepar chris59264 » 12 Déc 2013, 18:29
Ok mais c'est inutile , tu devrais corriger j'pense car dans ce cas la procedure devient plus laborieuse .
Ce qui inclue qu'il faut telecharger le kernel en plus, alors que non. Il faut se mettre juste à la place du debutant qui en lisant ta procedure d'install, va le faire alors qu'il n'en a pas besoin pour que son tel fonctionne.
Je le rappel, le kernel est inclue dans la rom.
chris59264
Message(s) : 2994
Messagepar zobr93 » 12 Déc 2013, 23:55
Pour ma part j'ai suivi le tuto sur xda et j'ai un souci : après un factory reset, le flash de la rom, des gapps, j'ai redémarré et sa met extrêmement beaucoup de temps genre une demi heure a rester sur la flèche qui tourne. J'ai rebooté, reflashé, pareil.
Merci de m'éclaircir si j'ai loupé une manip.
Modèle :Galaxy s GT-I9000 8GO + SD card 8GO
Rom :[4.2.2][ROM] Mackay Rom 2.999
Kernel :Mackay
Opérateur :Je suis chez Free.
zobr93
Message(s) : 10
Messagepar voyo » 13 Déc 2013, 09:33
Après quelques tentatives pour passer de la mackay 4.2 à la 4.4 je laisse tomber, cela me note un joli failed lors du flash de la rom !
Ayant fait tout les wipes je ne vois pas d'ou peu venir le soucis, j'ai de nouveau téléchargé la rom sur XDA (au cas où) puis relancé un flash et toujours la même histoire...
Pour être plus précis je viens de tenter de re-flasher cela me note:
"fixing permissions ...
set_metadata_recursive: some changes failed
E: Error executing updater binary in zip '/sdcard"
Si quelqu'un a une soluce je suis preneur!
Samsung Galaxy S (GT-I9000) Black (8 Go)
Mackay Rom : 4.1.3 [10/12/13]
[ROM AOSP] [KK 4.4.2]
CM11.0
BDB : XXJVO (BOUYGUES)
voyo
Message(s) : 12
